Enables the direct attach feature on the specified port.
port |
Specifies a single port on which to enable the direct attach feature. |
Off.
You should only enable the direct attach feature on ports that directly connect to a VM server running VEPA software.
This feature requires installation of the Direct Attach feature pack. For more information, see the Switch Engine v33.1.1 Licensing Guide document..
The following command enables the direct attach feature on port 2:1:
# configure port 2:1 reflective-relay on
This command was first available in ExtremeXOS 12.5.
